redirecting form on success
Thread begun 5/13/2019 7:41 am by Jamie | Last modified 5/16/2019 11:53 am by Ray Borduin | 2387 views | 8 replies |
Jamie
Hi Ray
Have got a contact form on every page of a site which on success should append to the page so that it uses the anchor link and also displays the success message
For some reason it doesnt do that, it redirects to itself but does not append the slug as above.
Am adding the form and relevant UE code as plugins and have attached the 2 main ones.
Cheers
Jamie
It looks like it would work to me. I'd have to debug it live... maybe a .htaccess rule is removing it? Maybe something else on the page is causing issues? What URL can I use to test with? Do I already have FTP access?
Jamie
Ahhhhh you are of course right. I checked on a non homepage instance and it works fine. The htaccess is set to remove index.php
#RewriteCond %{THE_REQUEST} ^GET.*index\.php [NC]
#RewriteCond %{REQUEST_URI} !/system/.* [NC]
#RewriteCond %{REQUEST_URI} !/kcfinder/.* [NC]
#RewriteRule (.*?)index\.php/*(.*) /$1$2 [R=301,NE,L]
How would I modify it to allow for the for submission?
I don't think that is the rule causing issues. You are using the URI for the redirect, so the redirect shouldn't add index.php, so it wouldn't be removed. If you remove that htaccess rule then it works? Might it be something else on the home page?
Jamie
Oh OK. Details in PM
I can't seem to get in via FTP. Please check the settings and make sure there are no typos.
Jamie
see PM
You had an older version of WA_Email.php on the site. Updating to the latest version fixed this issue.
Jamie
cheers :)
