Image file upload
Thread begun 5/06/2019 12:35 pm by john70964 | Last modified 5/22/2019 1:54 pm by Ray Borduin | 3433 views | 9 replies |
john70964
File image upload
Hello Ray
I created a page for uploading some images. I thought I had followed the instructions on page
http://www.webassist.com/tutorials/Resizing-images-on-upload but obviously not!
The image names are not being placed in the database and the images are not being placed in the images folder.
Can you see where I am going wrong please?
Many thanks
John
You have your file upload set to the recordset value instead of the form file field.
They are all wrong, but for instance:
'FileName' => "".($rs->getColumnVal("image10")) ."",
should be:
'FileName' => "[FileName]",
Your database update statement is only using one of the fields. You would have to update the MySQLi Update Table server behavior to add the other file upload fields. It looks like it is properly updating the imge1 field.
john70964
When Updating image fields with Mysqli Update Record I go to column Bindings and press the lightning bolt
I have a choice of Folders and files which can be selected.
Which should be selected for the File Fields?
Many thanks
John
The uploaded file "Server File Name" for each upload should be used to update the database.
john70964
Thanks Ray,
Maybe I did not quite understand the above answer.
I changed Upload File (Image1) to include serverFileName
I then received these errors when the page was run.
Notice: Undefined index: WA_UploadResult1 in C:\xampp\htdocs\boatsforsalenow_mysqli2\BoatAds180\boat_insert_images.php on line 48
Notice: Undefined index: WA_UploadResult1 in C:\xampp\htdocs\boatsforsalenow_mysqli2\BoatAds180\boat_insert_images.php on line 58
Notice: Undefined index: WA_UploadResult1 in C:\xampp\htdocs\boatsforsalenow_mysqli2\BoatAds180\boat_insert_images.php on line 68
Notice: Undefined index: Image2 in C:\xampp\htdocs\boatsforsalenow_mysqli2\webassist\file_manipulation\helperphp.php on line 72
I then changed this back to [FileName] and the errors were removed but a new one appeared
I also noticed that in the database some of the field entries were incorrect
Image1 shows the correct name
image1_250 shows the name cai3367b but has lost the .jpg part
image2 shows the correct name
image3 shows the correct name
image5 shows the correct name
I also tested on the remote server with the same results
You should not be using the file upload bindings in the file upload server behavior. I was referring to the bindings in Update Database server behavior.
Resized images should be named like: [FileName]_200
Then your Update Table server behaviors can reference the Server File Name bindings from each upload.
john70964
Hello Ray
I originally had only 2 File Fields per page.
On the test page I have 10
If I insert 5 images into the File Fields then 5 appear in the database.
If I insert 10 images into the File Fields then none appear.
Should I limit the File Fields per page?
It is probably the php.ini limits causing it to fail.
You may have to change the upload_max_filesize and post_max_size directives in your php.ini file to accommodate more files.
john70964
Hello Ray
I have a test insert a record form with three hidden fields
frontpageshow
my_class
Feature
When I update the form frontpageshow and my_class both insert 1 in the correct field.
Feature field remains empty.
I wondered if you can see why this should be?
I attach the file.
Thank you
John
You don't have a column value set for the feature column in your insert server behavior. You don't need to use a hidden form element to set a static value you can just set the value to 1 in the insert server behavior and skip the hidden form element.
