PHP version
Thread begun 5/06/2019 5:39 am by info404015 | Last modified 10/16/2019 10:34 am by Ray Borduin | 3475 views | 16 replies |
info404015
PHP version
Hi there,
I've had to upgrade my PHP version on the host to 7.3 but now the Power gallery pages are just white screens and not working.
Help! What can I do to fix this please?
An example page: http://www.antiquite-decoration-galerie309.com/powergallery/galleries/grid_fullsize/index.php?gallery=18&theme=dark
PowerGallery won't work on php7 yet. You will have to talk to your hosting provider about how to downgrade your php version to something less than php7.
mick358555Beta Tester
PHP 7 Compatibility
Ray, do you have a forecast for when Powergallery will be able to work under PHP 7 specifically 7.3?. I host on Fasthosts and they have been providing PHP 5 support albeit at an additional cost, but now they have removed PHP5 completely and I only have access to PHP 7.2 or 7.3
I don't have a time frame... If you send me your site information and FTP access, then I'll see if I can quickly update it for you.
Hi Ray, thanks for the speedy response and assist. Details in private message
The FTP information provided doesn't seem to work for me. Please test and make sure there are no typos and check to make sure there are no IP restrictions that might be preventing my access to your files.
Hi Ray, I have checked the detail I sent you and can confirm it was correct. I have provided some additional info in the private message area.
I've updated your gallery to be php7 compatible. Please let me know if you find any issues. I had to update a lot of code, so it is very likely that you could find issues in your testing.
Thanks Ray, I will get the changes tested as soon as I can. I need to get my provider to effect the PHP change so I can test. I'll let you know how it goes.
Hi Ray,
I have had PHP7.3 put back on the site. I have checked the powergallery and the existing gallery displays perfectly as I would expect. However it appears as though access to the admin site is unavailable as it will not resolve "soggypaws/powergallery/admin_gallery/index.php". Can you take a look please?
