Configure form persistence
Thread begun 5/03/2019 6:23 am by john70964 | Last modified 5/06/2019 10:08 am by Ray Borduin | 2068 views | 6 replies |
john70964
I was looking for information on how to build persistence in a field.
I found this but it does not explain how to do it
Is there a tutorial?
http://www.webassist.com/dreamweaver-extensions/css-form-builder
Many thanks
John
Just apply the Persistent Form Server Behavior on the action page of the form, and then the form values from that form will be available in the bindings to use on any page after.
john70964
Thanks Ray
I think the persistance is OK now but when I run the page I get an error.
Please see PM
Delete the line that refers to:
mailformatting_php.php
That is not used in the latest version and is leftover from the old email code.
john70964
Thanks Ray
I discovered another error on the thankyou page. Please see PM
It looks like there were two recordsets on the page with the same name, so the update to MySQLi left some old code behind. Just delete lines 38-43 and you should be ok. You can also delete lines 3-32 since those aren't being used anymore either.
john70964
Many thanks Ray.
