Hi, i used the MySQLi Server behaviours now for the first time, works fine. Unfortenately my htaccess files does not work anymore. I get an error: SELECT * FROM tbpaginas WHERE paginaid = 5 LIMIT 1 Truncated incorrect INTEGER value: 5.php/5. What cou
Thread begun 4/30/2019 9:27 am by info252084 | Last modified 5/06/2019 10:08 am by Ray Borduin | 1759 views | 4 replies |
info252084
Hi, i used the MySQLi Server behaviours now for the first time, works fine. Unfortenately my htaccess files does not work anymore. I get an error: SELECT * FROM tbpaginas WHERE paginaid = 5 LIMIT 1 Truncated incorrect INTEGER value: 5.php/5. What could be
htaccess:
Options -MultiViews
RewriteEngine on
#RewriteCond %{HTTP_HOST} ^www\.accofides\.be [NC]
#RewriteRule ^(.*)$ http://accofides.be/$1 [L,R=301]
RewriteBase /
RewriteCond %{REQUEST_FILENAME} !-d
RewriteCond %{REQUEST_FILENAME}\.php -f
RewriteRule ^(.*)$ $1.php
RewriteRule ^nl/diensten/(.*) /nl/diensten.php?paginaid=$1
RewriteRule ^nl/artikel/(.*) /nl/artikel.php?blogid=$1
RewriteRule ^nl/vacature/(.*) /nl/vacature.php?vacid=$1
url:http://accofidesbe.webhosting.be/nl/diensten/5
That is not an issue with your htaccess file. Please attach a copy of the page you are working on and I'll take a look.
info252084
ok
You have specified your parameter as an integer in your Recordset, but you are passing a string that begins with an integer. You probably just need to open the Recordset and edit the parameter and identify it as text instead of an integer.
info252084
THank you for your support. Case solved.
