Second Manage Relational Table function causing duplicate entries
Thread begun 4/25/2019 8:27 am by Justin@AdventDesign | Last modified 4/27/2019 3:37 pm by Ray Borduin | 1715 views | 4 replies |
Justin@AdventDesign
An earlier version of this update page, with only one Manage Relational Table function, seems to work just fine. However, when I added a second Manage Relational Table function, I'm now getting duplicate entries on the original table (rel_images). The duplicates seem to be a bit intermittent. If I only try the entry for the last item in the repeated checkbox, it works OK, but any other one I get a duplicate.
This is probably my fault and I'm missing something obvious. To do the second, I duplicated the first iteration and simply changed by hand the relevant information, being careful to name the query with a new name. I just can't seem to find the error that is causing the issue. Original ("withouttags") version and the new version that contains both are attached.
I was able to find and fix an issue related to having multiple MRT server behaviors in a single form. You can download and install the latest version to fix the issue.
After reinstalling you will need to open and re-apply both MRT server behaviors and then you will need to upload the new version of the queryobj.php file. Then your page should work properly.
Thank you for bringing this to my attention.
Justin@AdventDesign
Site still says 2.3.5 from March. Downloaded it but it still appears to be 2.3.5. Is that the update because that's what my current one says?
Yes. I need to go in and update the dates, but the files should be updated in your new installation.
Justin@AdventDesign
DW didn't want to recognize one of the MRTs on the insert page so I ended up deleting and reinstalling. But all is good. I tested the crap out of both pages and both relational tables insert and update flawlessly.
Thanks Ray! Phenomenal support as always!
