HTML editor server-sde value improperly coded
Thread begun 4/22/2019 3:23 pm by eric284736 | Last modified 8/13/2019 10:47 am by Ray Borduin | 3822 views | 16 replies |
eric284736
Hi Ray,
I am getting an error after running the DataAssist wizard for the update page.
It states that the server-side code is improperly coded and references this:
$CKEditor_initialValue = "".((isset($_GET["invalid"])?ValidatedField("SeaTripupdate","Description",false):"".$WADASeaTrip_update->getColumnVal("Description",false)."")) ."";
Know sure what the issue might b.
Thx
Eric
It should be:
$CKEditor_initialValue = "" .((isset($_GET["invalid"])?ValidatedField("SeaTripupdate","Description"):"".$WADASeaTrip_update->getColumnVal("Description",false).""))  ."";
eric284736
Ray,
I updated that line but I still get the error.
thx
Eric
eric284736
attached
Please attach a copy of the file and I'll take a look.
The code is very particular about the syntax. I've updated the code above to the correct syntax to prevent the error.
eric284736
Thanks Ray. I updated the code but it will not display the HTML editor.
See the screenshot
It seems like it would work. If you view source does it show an error? Can I get a url and FTP access to debug? I'm sure I can figure it out, but I'm not spotting the issue.
eric284736
Sure thing.
Thanks Ray!
Your page was missing this line:
<?php require_once('../webassist/ckeditor/ckeditor.php'); ?>
