Duplicate file name - rename new file
Thread begun 4/22/2019 8:23 am by paulshoe379536 | Last modified 4/22/2019 2:13 pm by Ray Borduin | 1065 views | 2 replies |
paulshoe379536
I'm using "File Manipulation: Upload Wizaard" to upload JPGs. I have set the action to "Rename new file" and rename to is set tp "[NewFileName]_[Increment]. With this setting it will rename the upload to "photo_1.jpg" and it creates a thumb image with the filename "photo_thumb_1.jpg". I there a way that I can change that so the files could be named "photo_1_thumb.jpg" instead? This would make it easier for me to identify a group of related images programatically.
I've made an update that will allow you to do this.
Just manually edit the code where it says:
'FileName' => "[RenamedFileName]_thumb",
and update it to:
Then replace your file: webassist/file_manipulation/helperphp.php
with the one I have attached.
paulshoe379536
Thanks again for your help Ray. Perfect!
