HTTP Error Code 403 Forbidden?
Thread begun 4/19/2019 12:47 pm by illbe322016 | Last modified 4/19/2019 1:46 pm by Ray Borduin | 706 views | 1 replies |
illbe322016
I am trying to create a connection to an existing database using the WA wizard, I enter the host, username, pw and database name, the screen starts to think and then I get this error. This is on a 1 and 1 server with a db that's been working fine for years. I have another connection to this on another site that seems to be working just fine. Would it have to do with the site I'm trying to set up being a subdomain and the current working site being a normal domain? For example I am trying to set up the connection at pya2019.lynchtest.com and the current working connection is at pennyanaero.com.
Thanks for any thoughts.
Tom
That is usually an issue with the domain URL or root directory. I can't seem to browse to that site. Dreamweaver needs to connect to the server through the testing server site definition in order to access your database. Errors are generally from that dialog. If you send me you site definition with FTP access then I could test to see if I can reproduce the problem.
