I setup a email form usinf webassist|send mail but there is no longer a jquery validation under the forms drop down. Was this dropped and how do we validate say an email field in a form.
Thread begun 4/07/2019 5:25 pm by p_vouers282571 | Last modified 4/09/2019 8:44 am by Ray Borduin | 2144 views | 4 replies |
p_vouers282571
I installed ecart then removed it and reinstalled databridge because I was having issues making pages. Since I did that I no longer have jquery validation that use to be under webassist forms. Did the latest build drop this?
No, that should still be available in the latest version of DataBridge. It is also included in eCart. It should be there.... maybe try reinstalling one more time and if you still have issues, post your phone number and I'll do screen sharing with you to help debug the problem and find a solution.
p_vouers282571
that did the trick :-)
Phil
Now if I can just find a good book on mysqli and php I might be able to solve the way I use to use date to create a unique number
You should be able to do the same thing. That hasn't changed.
p_vouers282571
yep, after I deleted the winfilecache file things came back to normal. think I'll make a shortcut to the winfilecache so I can delete it more quickly :-)
