Converting search pages from MySQL to MySQLi
Thread begun 4/03/2019 11:36 am by EmmaMorris | Last modified 4/15/2019 9:27 am by Ray Borduin | 5090 views | 23 replies |
EmmaMorris
I purchased the new Data Bridge as we spoke about. I believe the only pages I need to convert are the search_i.php, the results_i.php and the choice page (in this case, showdr_i.php.
1. I have converted the search_i.php page and it seems to work correctly. Until the others are done I wont know for sure 100%. No error messages. Attaching the converted page.
Reminder FYI: You created a custom wada_search page for me back when I first did this page. Will attach.
2. The results page seems to come up with the correct results to choose from but comes up with the deprecated message up top pointing to the wada_search. I attempted to convert this page but had issues, I assume due to the arrays or the custom code. Attached is a fresh copy of this page before mods.(MySQL code)
3. Showdr_i.php page. When I make a selection to view on the results page, this page will not show but has this error message up top:
"Fatal error: Can't use method return value in write context in /mydirectory/showdr_i.php on line 16"
I did the conversions for this page but not sure what to do with this line (16) and possibly (10-12).
If you could, let me know where to go from here.
Thanks so much.
Emma.
Showdr_i.php line 16 should be:
if (!$rsMain->getColumnVal('specialtiesID')) $rsMain->Results[0]['specialtiesID'] = 0;
The other lines should be fine on that page.
The search results page needs to be converted, both the recordset and the search, and since it uses custom code, some will have to be done manually.
I can't do that without FTP access. If you can send me FTP information for the site and a URL so I can browse the page for testing then I can update it for you.
EmmaMorris
I modified line 16 as well as line 24 as it was similar.
There are 3 sections that have mysql code still... Near lines 127, 154 and 170 that are definitely problems.
I tried manually converting manually but am having an issue.. guidance
I'll take a look at all of the remaining issues once I have a url to view them and FTP access.
EmmaMorris
I have fixed the problems on the showdr_i.php page.
So, at this point, as far as I know the only thing I need to address is the results_i.php page.
Because of the custom programming I did not want to try it.
Ftp info sent privately.
Emma
The results page has been updated to use MySQLi. Please also download the rsobj.php file used on the page.
EmmaMorris
Thanks Ray..
I have a few other things to check and pages to convert but they should be simple.
I so appreciate your help
Emma
EmmaMorris
Only problem I have found so far.
Instead of:
<?php echo($rsMain->getColumnVal("notes")); ?>
use:
<?php echo($rsMain->getColumnVal("notes",false)); ?>
The mySQLi code has automatic HTML Cross Site Scripting Injection protection, that needs to be disabled when you want to allow it to display html.
EmmaMorris
Great. That worked just fine. I have fixed several other little things on a couple of the pages.
One issue on the search_i.php page at the bottom Notes: just type in anything
The error points to the results_i page.
