How to clear search with new MySQLi structure
Thread begun 4/03/2019 8:05 am by Justin@AdventDesign | Last modified 4/03/2019 8:21 am by Ray Borduin | 961 views | 2 replies |
Justin@AdventDesign
With the previous version of DataAssist, I was able to 'clear' a search on the results page and show all by including "?clear=true" at the end of the URL string, and having this code on line one of the results page:
@session_start();
if(isset($_GET['clear']) && $_GET['clear'] == "true") {if(isset($_SESSION['WADbSearch1_tbl_images_results'])) unset($_SESSION['WADbSearch1_tbl_images_results']);}
I've looked, and experimented with various values in this code, and confirmed that "WADbSearch1_tbl_images_results" in the Sessions panel is the correct name.
Did something change when it switched to MySQLi? How do I remedy? Results page attached.
In the latest version you can use:
if (isset($_GET['clear']) && $_GET['clear'] == "true") {
$searchWADAtbl_images_WADbSearch1->clearSearch();
But you will have to move it below the search code for it to work properly. If you delete the current clear code, then add this, it will be at around line 41.
Justin@AdventDesign
Perfect Ray. Worked like a charm. Thanks!
