changing varchar count
Thread begun 4/02/2019 11:25 am by Patrice | Last modified 4/03/2019 9:12 am by Ray Borduin | 1910 views | 4 replies |
PatriceWebAssist
PowerStore> users table.
Client wants to limit the number of characters in a company name, etc. It is currently set to varcher(100). He wants it set to 35. So far so good. However, since the cart has been active for a couple of years, there are some companies with longer than 35 characters, so phpMyAdmin is not allowing the change. Is there a way to force the change? Alternately, is there a way to search in the cart admin for longer names? I didn't see a way yet.
One way maybe for me to set up a page that reflects all the companies in a list, associated with the ID, then change directly in the db.
Any other ideas, most appreciated.
PatriceWebAssist
I set up a page to reflect the ID number and the field names. The client can use the ID number to find the customer, then edit each longer entry, then I can reset the varchar as needed.
But if anyone knows an easier way, please share. Thanks much.
Just run the SQL statement: UPDATE users SET CompanyName = SUBSTRING(CompanyName , 1, 35)
PatriceWebAssist
Thanks so much Ray. Probably above my pay grade to get it done. There are 3 fields on 2 carts. I'll check with client to see if I can open a ticket with you.
I did set up the visual pages for client to see what is what, and I think they are working thru finding the longer names manually in the ID user search. I suspect they can get it done that way. Fingers crossed. Once they cut back on the field content, I will be able to change from 100 to 35 varchar. If it doesn't work out, then I will open a ticket. Thank you.
PatriceWebAssist
I figured out how to do it. I ran tests on my demo cart. I used the following
UPDATE ps4_users SET UserCompany = SUBSTRING(UserCompany , 1, 35)
UPDATE ps4_users SET UserAddress = SUBSTRING(UserAddress , 1, 35)
UPDATE ps4_users SET UserAddress2 = SUBSTRING(UserAddress2 , 1, 35)
And then, that allowed me to set from 100 to 35. Thanks for your help, Ray.
