Data Bridge V2 and MySQLi server behaviours
Thread begun 3/31/2019 10:06 am by EmmaMorris | Last modified 4/02/2019 3:05 pm by Ray Borduin | 1489 views | 4 replies |
EmmaMorris
I have installed the new Data Bridge and have started the conversion of a few pages. My question is, should I install the regular MYSQLi server behaviors as well? (its a new install of Dreamweaver so there were none installed) The reason I am asking is on one page, my recordsets converted fine but there are some MySQLi Dynamic lists that are failing.. I did not want to install the behavior if it should not be installed.
Emma
It should not be installed. DataBridge v2 includes updated versions of all of the MySQLi Server Behaviors.
EmmaMorris
Perfect.. Thank you!
danielsebas
Hi Ray, so the only extensions that should work fine installed together are DataBridge V2 and eCart v6? Can you please update the DataBridge download page with compatibility information with the other extensions.
Thank you.
Regards,
Daniel
What compatibility information do you feel is missing? All of the extensions can be installed together. Just no need to install MySQLi Server Behaviors since it is included in DataBridge. It won't cause issues to have them all installed at once.
