Blank contact page
Thread begun 9/11/2009 7:24 am by chris384639 | Last modified 9/14/2009 1:48 pm by Jason Byrnes | 8683 views | 16 replies |
chris384639
Blank contact page
I created a contact form using CSS Form Builder. I then used Universal Email to send the form data to my email address.
Now I can't see anything on my page.
Any suggestions?
most likely, the problem is lines 1 - 2:
<?php virtual("/WA_ValidationToolkit/WAVT_Scripts_PHP.php"); ?>
<?php virtual("/WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php"); ?>
they should probably be:
<?php require_once("../WA_ValidationToolkit/WAVT_Scripts_PHP.php"); ?>
<?php require_once("../WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php"); ?>
Dreamweaver will use the virtual() function for included files if the "Create links relive to" option on the local info tab of your site definition is set to "Site". If you change this to "Document" Dreamweaver will use the require_once() function instead.
chris384639
Hi Jeff-
I made the adjustment, but still the same result.
add the following to line 1 to turn on error reporting:
error_reporting
(E_ALL);
chris384639
Same result... attached is an updated file w/ code.
Can you post a link please.
Also, double check that your changes are making it to the server, delete the copy on the server then reupload.
chris384639
index3.php
have you uploaded the validation toolkit folder?
both:
and
Give a 404 page not found error. This folder and the WA_UniveresalEmail folder will need to be on the server.
chris384639
ok... i made sure I uploaded the folders... still same result.
btw- thanks for the help- we're almost there.
one more thing I would like you to try for me, I'm not 100% convinced the changes are being uploaded.
delete the index3.php form the server once again, but dont upload it. the try browsing to:
index3.php
Instead of a blank screen you should get a 404 page not found error.
If that test yields a 404 page not found error, I would like you to send the WA_ValidationToolkit and WA_UniversalEmail folder so I can reproduce the problem on my end.
