Can't Insert a Repeat Region
Thread begun 3/29/2019 1:19 pm by rmiller396212 | Last modified 4/02/2019 10:18 am by Ray Borduin | 947 views | 2 replies |
rmiller396212
I'm in my first day with WebAssist, but am having a pretty basic problem. After inserting a recordset, and with that recordset specifically listed at the top of the Server Behaviors tab, I am trying to insert a repeat region, but am getting the message "Before using this server behavior, please insert a Recordset." What am I doing wrong? Thanks.
You are probably using a standard recordset and a MySQLi repeat region or vice-versa. There are two versions of the repeat region corresponding to the type of recordset you have on the page. Also make sure you can open and test your recordset.
rmiller396212
Thank you Ray. That's the problem. I had inserted a MySQLi recordset but didn't realize I needed to use the MySQLi menu at the top to insert the Repeat Region. I was using the Server Behavior Tab. Appreciate your help.
