Page redirect not working
Thread begun 3/28/2019 11:49 am by iain331081 | Last modified 5/12/2020 10:43 am by Ray Borduin | 1926 views | 9 replies |
iain331081
I had a similar issue with a page not that long ago, which was broken because of spaces in the PHP code at the top of the page. I've had a look for stray spaces with this one, but haven't spotted any.
Its mostly working - the email is being sent when the form is submitted, and the form contents are correctly being inserted into a database table.
But I'm just getting a white screen with the same URL as the contact page, and its not redirecting.
I have attached a copy of the file below - if you can a look and see if you can spot what's causing this, that would be great.
Thank you!
Add this to the top of the page:
ini_set("display_errors",1);
Maybe that will give you an error message and line number to go on. I can't see the problem on the page, so maybe the issue is with one of the include files.
iain331081
Thanks Ray - just been having a look. Looks like its something with the mail include, waue_contact_1.php.
Error is:
Catchable fatal error: Object of class WA_MAILOBJ could not be converted to string in /home/safariaw/public_html/webassist/email/waue_contact_1.php on line 62
You have a stray $ on line 59. Try deleting that and see if it helps.
iain331081
Thanks Ray - that was indeed the culprit.
Philippe
Same problem,
Hello Ray,
I have been looking for several days but there I am lost
I made an email form in which I entered the recipient's address with a body file with dynamic value and everything works fine.
But when I added a query in the contact page to display the name of the site nothing works and the redirection does not happen.
I got this error message:
Warning: Cannot modify header information - headers already sent by (output started at /home/foyercul/www/contactez-nous.php:26) in /home/foyercul/www/webassist/email/WA_Email.php on line 405
Then I moved this line at the top off the contact page <?php require_once("webassist/email/WA_Email.php"); ?>, as you can see in the file, this message disappeared but another one is displayed :
Fatal error: Call to a member function query() on a non-object in /home/foyercul/www/webassist/mysqli/rsobj.php on line 215
When I want the recipient e mail from database to send it to one or 2 recipients in bcc the email is not sent
I have a main site in php 5.4 which I rewrite with databridge and a mobile site in subdomain on the same shared server OVH in php 7.03 and the problem is the same.
I just removed this : $Email->addTo("webmaster@foyerculturel.org");
To this : $Email->addTo("".($site->getColumnVal("mailcontact")) ."");
i received the email but i got this error and redirection don't work i have à blank page
Warning: Cannot modify header information - headers already sent by (output started at /home/foyercul/www/contactez-nous.php:34) in /home/foyercul/www/webassist/email/WA_Email.php on line 405
As soon as I remove any request everything is ok.
You have a blank line of code on line 33 like:
A redirect can't happen after anything is written to the page including a blank line. Update it and remove that line so it is:
Philippe
Page redirect works
Thanks a lot Ray everything works fine
Another question, is there any way to remove the last line from the body file ?, ie Default submit:?
Yes. On the top of the email body file on lines 28-29 you will see:
$removeIncludes = array();
$removeIncludes[] = "Security";
Just add:
$removeIncludes[] = "Submit";
That will remove any form element that includes the word "Submit" from the results.
Philippe
Thanks Ray it works.
For information in my contact page the word submit is written submit and not Submit, so it's case sensitive.
I had to write
$removeIncludes[] = "submit";
