XSS Scripting
Thread begun 3/28/2019 8:37 am by Jamie | Last modified 4/04/2019 9:39 am by Ray Borduin | 2990 views | 13 replies |
Jamie
XSS Scripting
Hey Ray
Have been contacted by someone from 'open bug bounty' - have looked into them and they seem legit? - but they have said that a site I have (in the PM) has a xss vuklnerability. They havent provided more details than that at this time.
Just wanted to ask if this was to do with the the action="<?php echo (htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)); ?>" in the contact form element and not requiring it filled in?
Or is it something else?
Cheers
Jamie
Remove the action tag or set it to action="". That should fix it.
Jamie
Thanks very much. Is it only a contact form that I need to be looking at?
I would do a site-wide search for:
and:
$_SERVER["QUERY_STRING"]
and make sure they aren't in an echo statement in the html anywhere.
Jamie
thanks Ray
couple of follow up questions on this
1. is replacing $_SERVER["PHP_SELF"] with $_SERVER["REQUEST_URI"] ok?
2. is this ok as <form id="form1" name="form1" method="post" action="users_login.php?failed=1<?php echo(isset($_SERVER["QUERY_STRING"])?"&".($_SERVER["QUERY_STRING"]):""); ?>" class="form-container formLogin">?
No. That will cause issues too. Even REQUEST_URI is dangerous. The form action should be changed to action="" if it posts to the same page it is on.
Jamie
ok thanks. another follow up is that I have navigation (attached) that uses a combination of both to select the on state depending on the page you're on - am I going to need to change this and how would I dynamically select the page/onstate ?
That doesn't need to be updated. You can check those values and use them in IF statements without issue. The issue occurs when they are written into the html, and that isn't done in this file.
Jamie
thanks for all your help on this. Have had a follow up, details in PM
It looks like there is a typo in the file: webassist/form_validations/wavt_validatedform_php.php
if ($encoded) htmlspecialchars($retVal);
should be:
if ($encoded) $retVal = htmlspecialchars($retVal);
I'll get it corrected in the next update.
