Incorrect Page opens
Thread begun 3/27/2019 12:48 pm by john70964 | Last modified 4/02/2019 9:47 am by Ray Borduin | 1774 views | 6 replies |
john70964
Hi Ray
I have a page where the incorrect page opens. I cant see why the wrong page opens.
Would you please have a look.
The correct path is index.php > boat-details.php > Enquiries/boatenquiry.php? > Enquiries/confirm.php
But the path taken is index.php > boat-details.php > Enquiries/confirm.php
in boat-details.php
line 171 seems to indicate the correct path
<form class="DetailsPage Basic_Default" id="Details_Basic_Default" name="Details_Basic_Default" method="post" action="Enquiries/boatenquiry.php?RecNo=<?php echo($WADAboats_details->getColumnVal("RecNo")); ?>">
I am attaching the pages.
Thank you
John
How can I reproduce the problem online? I'm not quite sure what I'm looking at here.
john70964
Please see PM
The issue is that the boat-details.php page has an insert server behavior that runs with the trigger "any form post" that then redirects to the confirm.php page.
The form post from the index.php page counts as "any form post" and initiates the insert and redirect on the details page. I changed the trigger to be on the Insert Button Press instead and that seems to have fixed the problem.
john70964
Hello Ray,
I have the files all showing the correct information and an email is received from the remote server but when the email arrives the details are blank as attached.
Many thanks
John
Your email body is still referencing the recordset values using the old syntax like:
$row_rsConfirm['email']
instead of the new MySQLi syntax like:
$rsConfirm->getColumnVal('email')
The easiest way to fix the problem is to manually update the page:
webassist/email/waue_confirm_1.php to use the correct recordset references.... I've gone ahead and done that for you since I have ftp access.
john70964
Thank you so much Ray for solving my problems as of course you always do!
Top support!!
Best regards
John
