Can the log in behavior be configured to use the username and passwords stored in Joomla?
Thread began 3/26/2019 2:18 pm by davidgard | Last modified 3/27/2019 10:05 am by Ray Borduin | 372 views | 1 replies |
davidgard
I have created an external web program that I want my Joomla users to have access to using the same credentials from the Joomla site. I can access the Joomla user tables both directly or through a view, but am not sure what encryption algorithm is used or how to configure the login function to interpret the Joomla user password. How can I accomplish this with the login behavior?
I think joomla uses a blowfish hash for passwords. There is a manual update to the webassist authentication that would allow you to set this up. You need to manually update the ->addFilter($filterColumn, $filterComparison, $filterType, $filterValue) method to use ->addHash($hashColumn, $hashComparison) instead after applying the server behavior.
I'm not positive that would work, but that is what I would try and I think there is a good chance it would.
