Dreamweaver versions for v2
Thread begun 3/21/2019 5:15 pm by Nixtev | Last modified 3/25/2019 9:30 am by Ray Borduin | 1554 views | 2 replies |
Nixtev
Does DataBridge v2 definitely only work with Dreamweaver CS5.5 and higher or was it just not tested fully on anything prior to that?
I was running the beta version on CS4 without any noticeable problems so would like to upgrade but no point if it won't work.
I swore I'd never give Adobe any more money after they bought out Interakt then killed it all off, hence being still on that version!
It should still work on CS4 and above. The only thing that changed right around then is the use of .zxp instead of .mxp for installing and the introduction of the mm.browsercontrol, which we use for the visual query builder and data mapping, but really those aren't necessary to use the tools. Give it a try and we will give you your money back if it doesn't work for you... just let me know within 15 days of your purchase if it is missing something critical.
Nixtev
Thanks Ray, I'll order it when I've got a bit more time to play with it and try it out properly as this week is a bit hectic so don't want to leave it unused for too long.
