WA_Auth_RulePasses text area on cart.php showing in mobile view regardless of conditions
Thread begun 3/21/2019 10:39 am by graham | Last modified 3/28/2019 10:10 am by Ray Borduin | 3024 views | 11 replies |
graham
Hi, Ray ... awhile back you helped me in a Premier Support session to add a wholesaler element to my checkout process. Part of it was to implement a minimum quantity check, which included a simple text area appearing under the quantity box on the cart page to indicate the specific minimum for that product. The area was to show if ((WA_Auth_RulePasses("Wholesaler") && $eCartNewPurple->DisplayInfo("minimumQuantity"))) ... works great ... except, in mobile view it always shows, regardless of whether RulePasses or not. I wonder if you could take a quick look?
Also, there seems to be an issue with updating quantity for any item on mobile (Android) ... change it and hit Go - the update prompt appears for a second, but returns to product page without updating cart. I have found another thread where you mention Android issues with onfocus and onkeypress, but couldn't figure the fix in my case. I realize this might be better handled in a separate thread, but, while you have it open ? :)
Thanks as always, Ray
I'll need a URL to reproduce and FTP access to debug this. It is too difficult to set up everything necessary to debug on my side.
graham
Morning, Ray .. I PM'd my FTP in case you have time to look at the Premier Support related issue of notation text showing up in mobile view regardless of Rules - thanks. As for the update quantity issue for mobile, should I post this into another thread for reference?
Happy Friday!
On cart.php line 280 you have:
if (1==1 || (WA_Auth_RulePasses("Wholesaler") && $eCartNewPurple->DisplayInfo("minimumQuantity"))) {
it should just be:
if (WA_Auth_RulePasses("Wholesaler") && $eCartNewPurple->DisplayInfo("minimumQuantity")) {
That is why it is always displayed. I updated that and I added a script to the bottom of the page to make sure the GO button just closes the window and doesn't submit the form.
graham
Thanks, Ray ... have a great weekend.
graham
Morning, Ray ... sorry to bother you, but the above issue with updating quantity seems to still exist on mobile - I change the quantity, hit Go and the update button shows for a second before reverting to product details page without updating the number. You added a script, but I am not sure if I downloaded the amended cart.php to my local folder before working on the page ... I may have uploaded over it (?). I fixed the (1=1) problem, but can't get the update to work. Would you have a moment to help again? Thanks so much.
This is the script I added to disable the "Go" button:
<script>
jQuery(document).ready(function() {
jQuery('.mobileQty').keypress(function(e) {
var code = (e.keyCode ? e.keyCode : e.which);
if ( (code==13) || (code==10))
jQuery(this).blur();
return false;
</script>
Just add it right before the </body> tag on the cart.php page if you accidentally removed it.
graham
Thanks, Ray ... I did overwrite it :) However, I added it now and tested that it works in Firefox browser, but not Chrome (?). Thoughts?
What exactly doesn't work in chrome? How do I reproduce it?
graham
Testing on Android, add item to cart - tap quantity and change number - hit Go and update shows for a second, but reverts back to product detail page. Works fine on Firefox.
