multiple insert from a checkbox list
Thread begun 3/15/2019 8:28 am by gb261593 | Last modified 3/19/2019 2:06 pm by Ray Borduin | 3663 views | 13 replies |
gb261593
I have a database used to manager free legal advice. I have a table 'advicetype' which has fields workid and notes. Also a table 'advice' which, amongst others, has fields adviceid
and matterid.
During the advice process I want to be able to list all of the advicetype notes in a table with a checkbox next to each of them. This would allow a user to check all of the advice types that apply for that session. On clicking Submit this would then insert each of the checked items into a new record in table jumcmatteradvice which has fields including workid.
Is this possible using Data assist?
Yes. You can do that with the multiple insert server behavior.
gb261593
Are there any detailed instructions anywhere that have checkboxes mentioned?
Not that I know of. Checkboxes work exactly the same as any other input element, so their would be no reason to do a tutorial specific to checkboxes.
If you are using MySQLi, then you don't even need to use multiple insert. The standard insert server behavior will work with arrays like checkbox groups.
Just:
1) Add your checkbox to the page and name it with brackets like: <input type="checkbox" name="toinsert[]">
2) Bind the value of the checkbox to the recordset and use a Repeat Region Server Behavior to repeat the recordset for all of the rows
3) Apply the insert server behavior and use the "array" version of the checkbox to insert and one row will be inserted for each value checked automatically.
The best thing to do is try and post here when you get stuck.
gb261593
Thank you. I will try this and get back to you if necessary.
gb261593
Many thanks - this works perfectly. My only issue is with the repeat selection part. (I am following the tutorial at http://www.webassist.com/tutorials/Create-a-multiple-record-insert-form). During this you have to select a number of repeats. My recordsets are variable in length so I enter a number that is the largest (70 in my case) . This is OK but leaves blank lines at the end. Do I have to have a number there and if I do how can I get it to just be the max I need? I think the line is
$RepeatSelectionCounter_1_Iterations = "70";
Use repeat region instead of repeat selection and then you can have it repeat on all records in a recordset.
gb261593
I tried that. I used the Repeat Region from the standard DW menu not anything from DataAssist. The list was OK but it only inserted one record.
I'll need to see a copy of the page to determine what is wrong. Are you using MySQL or MySQLi?
gb261593
I am using mySQL. I have sent you the page in question. Many thanks
