I want to show 0 results if nothing has been searched rather than show all results
Thread begun 3/14/2019 1:14 pm by jo271221 | Last modified 3/15/2019 8:32 pm by Ray Borduin | 2270 views | 7 replies |
jo271221
I found this resolution and I attempted to add on my page after line 27, that did not work and I tried after line 199. There is some code modification for sorting which I believe is complicating things.
jo271221
I am attaching my page.
Please attach the page... There should be a "default where clause" setting in the database search. You can set it to "0 = 1" and that should return no results if no search is performed. (depending on the version you may need to set the default where clause to "WHERE 0 = 1")
jo271221
Assuming the wada_search.php is the file you need I have attached it.
Thank you,
on search-all-results.php on line 10 you have:
$WADbSearch1_DefaultWhere = "";
Try using:
$WADbSearch1_DefaultWhere = "WHERE 1=0";
If that doesn't work try just:
$WADbSearch1_DefaultWhere = "1 = 0";
jo271221
I tried both of those options and I am still getting all results.
There was some custom code on the page that overwrote how the search worked by default. I went in and fixed it.
jo271221
Thank You!
