File Upload Overwrite
Thread begun 3/14/2019 11:35 am by vernon webb | Last modified 3/18/2019 10:06 am by Ray Borduin | 1790 views | 5 replies |
vernon webb
Ray,
For some reason when a file is uploaded and a file name exists, the file is being renamed but it is not being renamed properly (it adds an _1 on the end but actually does not tag the ext .pdf to it) and the database is NOT being updated to reflect the new file named (I know this because when you go look at the record the old file is still listed there.)
I added the current file to the display in the popup and it appears to be working for me. Maybe it has something to do with the file you are uploading? Maybe it is too large?
vernon webb
I don't understand what you said, you added the current file to the display? Anyway, it has nothing to do with the file as I had him rename the and it uploaded just fine.
Please provide steps to reproduce including attaching the file you are using to reproduce and how you are verifying that it doesn't work. I'll reproduce and debug it. It worked properly with the sample file I used.
vernon webb
I'm attaching the file that is there now as I had them rename the file (which now has TEST on it) which I would imagine would reproduce the same result
The issue is with uploading files that have a "." in their name. I made an update to the webassist/file_manipulation/helperphp.php file to account for files with a "." in the name.
