DataAssist Pages Broken
Thread begun 3/12/2019 8:32 am by vernon webb | Last modified 3/14/2019 12:44 pm by Ray Borduin | 1977 views | 7 replies |
vernon webb
I created a set of pages using the DataAssit Pages. I've inserted an item into the database and as soon as it went to the details page it was broke. It also does not show up in search results, however when I open the recordset with Dreamweaver to see if the record was actually inserted it was indeed there. Point being there are records, but they are not showing.
I'll need FTP access to debug this issue. Please update all threads with updated FTP information where I've requested it and I can look into them individually.
vernon webb
Updated...
The wizard didn't complete or run properly. It looks like the recordset that is supposed to be on the details page is on the results page. I'd re-run the wizard and see if it creates the pages properly this time.
vernon webb
I did it again, but it seems to have still gone awry. Everything but detail page seems to be working right.
vernon webb
I looked at this page and for some reason the recordset was not created using the wizard. I went in and manually created it. I also had to remove:
<div>
<div>This record has been removed.</div>
</div>
<hr/>
since the record was not being deleted. There was nothing around it that stated it should be displayed if...
Maybe go to WebAssist->Preferences and update your Wizard Settings to increase the delay while running the wizard. Sometimes it can run too fast for Dreamweaver to keep up and produces inconsistent results.
vernon webb
I will if I need to right now I manually fixed it, it was more an FYI to you.
