show record count
Thread begun 3/05/2019 3:21 am by Sweens | Last modified 3/06/2019 9:59 am by Ray Borduin | 1267 views | 3 replies |
Sweens
show record count
Hi Ray
As soon as I try to add MySQLi 'Display Record Count' starting number or ending number
I get:
There is an error in your SQL syntax.
The same applies when I try to add any of the 'show if x page'
Strangely, the total records count works fine.
Cheers
Chris
That is odd... what version of the rsobj.php are you using? I'd need a URL to reproduce the issue and FTP access to fully debug, but it may be addressed if you reinstall DataBridge and use the latest version of the rsobj.php.
Sweens
Thanks Ray - I'll try that.
Strangely, when I updated a page from the earlier version of DA, the paging worked fine - and it produced the identical code to that I tried on a new page!
Cheers
Chris
It may have been the version of rsobj.php
