"Undefined Index" error with insert multiple records behavior
Thread begun 2/28/2019 9:41 am by Justin@AdventDesign | Last modified 3/01/2019 9:08 am by Ray Borduin | 1764 views | 5 replies |
Justin@AdventDesign
Attempting to manage relational tables following the tutorial http://www.webassist.com/community/tutorials/view_tutorial.php?tid=25&accesscheck=/community/tutorials/view_tutorial.php?tid%3D25 - I'm aware this tutorial was written for MySQL rather than MySQLi, but It's my understanding the basic process is the same.
- I've eliminated the redirect on the existing insert behavior
- I've pulled the options table (tbl_homes) information and repeated it with the 'id' column properly inserted in the checkbox field
- I've tried to apply the insert multiple records behavior
I've tried tearing down and rebuilding several times, but I keep running into the same consistent error:
"Notice: Undefined index: wamultiinsert_1 in /Applications/XAMPP/xamppfiles/htdocs/sites/abm-sites/team-construction/sitecontrol/tbl_images_insert.php on line 29"
Page attached.
You have your trigger set to "always" for the multiple insert. It needs to be set to the button press for the submit button like the first insert.
Justin@AdventDesign
:facepalm:
Sorry about that. I thought I had experimented with that but must have missed it.
After making sure the insert multiple records function comes after the original insert, I’m still having a bit of trouble getting it to submit the proper binding values. The tutorial says for the ’item’ id choose the session variable for the insert. In my case that would be WADA_Insert_tbl_images. For the ‘option’ id, choose the form item. It appears I have the options of wamultiinsert_1[] (csv) and wamultiinsert_1[] (array). I’ve tried both.
However, rather than only submitting the checked item ids, the records it set just repeat the same option id that is the first in the list of records (in my case ‘home_id’) for 5 (the total number of results of the rsHomes) times. I’m guessing I’m missing something simple, but I can’t seem to find the step I missed here.
Justin@AdventDesign
Found the skip if empty... which has stopped the repetition, but no matter what I select, I can't seem to find the right variable for the option table id (tbl_homes) repeated from the rsHomes recordset. It just repeats null or 0. Any direction on what I'm looking for?
if (isset($_POST["Insert"]) || isset($_POST["Insert_x"])) {
$MultipleInsertConnection = $framework_connect;
$MultipleInsertTable = "rel_images";
$MultipleInsertRedirect = "tbl_images_results.php";
$MultipleInsertCheck = "rel_homes";
$MultipleInsertIdentifier = 'wamultiinsert_1';
for ($mi=0; $mi<sizeof($_POST[$MultipleInsertIdentifier]); $mi++) {
$MultipleInsertCount = $_POST[$MultipleInsertIdentifier][$mi];
if (($MultipleInsertCheck == "" || (isset($_POST[$MultipleInsertCheck.'_'.$MultipleInsertCount]) && $_POST[$MultipleInsertCheck.'_'.$MultipleInsertCount]!=""))) {
$InsertQuery = new WA_MySQLi_Query($MultipleInsertConnection);
$InsertQuery->Action = "insert";
$InsertQuery->Table = $MultipleInsertTable;
$InsertQuery->bindColumn("home_id", "i", "".((isset($_POST["wamultiinsert_1"."_".$MultipleInsertCount]))?$_POST["wamultiinsert_1"."_".$MultipleInsertCount]:"") ."", "WA_IGNORE");
$InsertQuery->bindColumn("image_id", "i", "".$_SESSION['WADA_Insert_tbl_images'] ."", "WA_IGNORE");
$InsertQuery->execute();
if ($MultipleInsertRedirect) {
if (function_exists("rel2abs")) $MultipleInsertRedirect = rel2abs($MultipleInsertRedirect,dirname(__FILE__));
header("location: " . $MultipleInsertRedirect);
When it says:
" For the ‘option’ id, choose the form item."
It means to select it from the dropdown list... not using the lightning bolt and bindings that appear there. The values you are selecting are not the correct ones. The correct ones should be select-able from the list.
Justin@AdventDesign
The instructions mentioning clicking on the 'lightening bolt' so that was what was throwing me. This appears to work now. Thanks!
