How to code within the latest Send Email behaviour?
Thread begun 2/25/2019 4:29 pm by Steve | Last modified 2/27/2019 10:03 am by Ray Borduin | 1250 views | 3 replies |
Steve
Looks like we lost the last versions methods of assembling the <body> of an email in the same basic code that is created when we do a Send Mail. There used to be the option that used an "include" such as:
include("../webassist/email/waue_mod_leadsx_1.php");
This causes me to lose access to some local recordset values. So to work in the newer version, I have created a variable that determines which email template to use.
if ($memberDetails->getColumnVal('mEmailTemplate')!='') {
$targetEmailTemplate = $memberDetails->getColumnVal('mEmailTemplate');
} else {
$targetEmailTemplate = "GenericReply.php";
No problem, this works BUT it renders the error alert as shown below.
Does DW create this alert or WebAssist?
Is the alert due to the way the variable is rendered in this line? :
$Email->BodyFile = "../webassist/email/templates/".$targetEmailTemplate."";
That is generated by WebAssist. If you send me the page you are working on so I can reproduce it, then I can get it to stop showing that message in this case.
Steve
File attached...
I've done an update so that this message won't show until you open the Server Behavior. If you reinstall the extension, then this error will no longer occur while simply viewing the page.
