add to dictionary / image dimensions
Thread begun 2/22/2019 5:52 am by Sweens | Last modified 2/22/2019 11:19 am by Ray Borduin | 1087 views | 2 replies |
Sweens
Hi
Am I mistaken in remembering that in earlier versions of ckeditor there was the facility to add to a dictionary? It's not there now - is it possible?
Also, is it possible to remove the image dimensions box on the upload form - or set it so both vales are empty on upload, As things are meant to be responsive now, this can cause images to exceed available width on mobiles/tablets.
Chris
I don't remember seeing an add to dictionary in older versions. The current documentation doesn't seem to have dictionary updates listed:
https://ckeditor.com/docs/ckeditor4/latest/guide/dev_spellcheck.html
I'm sure it is possible to remove the dimensions box on the upload form, or default them to blank, but it would require hand coding that I haven't done personally. I did a google search and found a few threads that discuss this like:
https://stackoverflow.com/questions/28356098/how-do-i-configure-the-image-properties-dialog-box-in-ckeditor
If you aren't successful on your own, this is something I could do for you in a premier support ticket.
Sweens
Thanks Ray - I'll have a go.
Cheers
Chris
