sql error after follow your new Tutorial "Dynamic Dropdowns with Data Bridge 2.0"
Thread begun 2/14/2019 10:59 am by Jonas | Last modified 2/14/2019 2:42 pm by Ray Borduin | 1336 views | 3 replies |
Jonas
I get the following error after done this new tutorial. Whats wrong?
"SELECT * FROM teams WHERE teamTown = %s ORDER BY teamName ASC
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '%s ORDER BY teamName ASC' at line 1"
Install the latest version of DataBridge... there was an error in a previous version where it would replace ? with %s when you add the dynamic dropdown.
You can manually change it back to ? in your recordset on the page to fix the problem.
Jonas
Now I have reinstalled the latest version of DataBridge (234), which I had already installed !?
But it still writes the same error.
This does nothing for now - if it is so simple that it is just to replace with a? Sign.
I have gone through the tutorials several times but still get wrong. The Child menu is not displayed, but instead all the teams appear when I choose a city.
this:
<?php if ($rsTeams->TotalRows == 0) { // Show if mysqli recordset empty ?>
  <select name="teams" id="teams">
    <option value="0">Then choose a team</option><?php // Show if mysqli recordset empty ?>
should be:
