MySQLi behaviors using Floating Point Numbers & Double where the column is an Integer
Thread begun 2/12/2019 12:53 pm by TroyD | Last modified 2/13/2019 8:41 am by Ray Borduin | 841 views | 2 replies |
TroyD
I'm curious about why each time I update an older behavior such as Update & Insert the new MySQLi version uses Floating point numbers as the type for the "Lookup column" ID and uses Double for the binding "Submit as:".
The columns being updated or inserted into, are int(11).
The conversion is working great and I can easily change it back to an int, but I was wondering if the extension was seeing something I am overlooking.
In most cases, the value is provided by a form field but sometimes it's a session. When I open the Update wizard and look in bindings, it shows int(11) in the type column but for each line it has Double selected instead of int. Do I have an issue somewhere I need to address? Would it even make a difference?
By the way, this has also happened when converting an older recordset that has a parameter compared to an id which is an integer. But this happens only occasionally.
Thanks,
TroyD
It shouldn't actually make a difference. I'll look into it though. I wasn't aware it was doing that. In the older recordset there was only "numeric" and "text", so when updating it doesn't really know what data type, so floating point and double (same thing) are the safest guess.
TroyD
Thanks Ray,
That makes sense to me. I can't imagine how you could make it work any differently that it does. I will simply adjust it if needed. The conversion has been working really well for recordsets, inserts and updates so this is minor. I was just making sure.
TroyD
