Automatically calculating, and displaying, somone's BMI in a form field using data the user has submitted in seperate height and weight form fields
Thread begun 2/08/2019 2:27 pm by Nathon Jones Web Design | Last modified 8/18/2020 2:45 pm by Ray Borduin | 2709 views | 6 replies |
However, it's made more complicated because I am giving the user the option to choose:
1) Height as either CM or Feet & Inches
2) Weight as either Kg or Stones & Lbs
It's also made complicated by the fact that there is WebAssist Validation running on the form AND that this is an UPDATE form. Here's where I've got to so far, on this specific section:
<div class="form-group row">
<label for="Height" class="col-sm-4 col-form-label">Height</label>
<div class="col-sm-8">
<div class="row">
<div id="FeetInches" class="col HeightOptions">
<div class="input-group mb-2">
<input type="number" class="input Height form-control" name="HeightFt" id="HeightFt" placeholder="Feet" value="<?php echo(isset($_GET['v2'])?ValidatedField("healthscreeningform_476","HeightFt"):$rsEDITFORM->getColumnVal("HeightFt")) ?>">
<div class="input-group-append">
<div class="input-group-text">ft</div>
</div>
<input type="number" class="input Height form-control" name="HeightIn" id="HeightIn" placeholder="Inches" value="<?php echo(isset($_GET['v2'])?ValidatedField("healthscreeningform_476","HeightIn"):$rsEDITFORM->getColumnVal("HeightIn")) ?>">
<div class="input-group-text">in</div>
</div>
</div>
</div>
<div id="Centimetres" class="col HeightOptions">
<input type="number" class="input Height form-control" name="HeightCm" id="HeightCm" placeholder="Centimetres" value="<?php echo(isset($_GET['v2'])?ValidatedField("healthscreeningform_476","HeightCm"):$rsEDITFORM->getColumnVal("HeightCm")) ?>">
<div class="input-group-text">cm</div>
</div>
</div>
</div>
<div class="col">
<div class="button dropdownHeight">
<select name="HeightSelector" id="HeightSelector" class="form-control">
<option value="" <?php if (!(strcmp("", (isset($_GET['v2'])?ValidatedField("healthscreeningform_476","HeightSelector"):$rsEDITFORM->getColumnVal("HeightSelector"))))) {echo "selected=\"selected\"";} ?>>Please Select</option>
<option value="FeetInches" <?php if (!(strcmp("FeetInches", (isset($_GET['v2'])?ValidatedField("healthscreeningform_476","HeightSelector"):$rsEDITFORM->getColumnVal("HeightSelector"))))) {echo "selected=\"selected\"";} ?>>Feet &amp; Inches</option>
<option value="Centimetres" <?php if (!(strcmp("Centimetres", (isset($_GET['v2'])?ValidatedField("healthscreeningform_476","HeightSelector"):$rsEDITFORM->getColumnVal("HeightSelector"))))) {echo "selected=\"selected\"";} ?>>Centimetres</option>
</select>
</div>
</div>
</div><!-- /row -->
</div>
</div>
<label for="Weight" class="col-sm-4 col-form-label">Weight</label>
<div class="row">
<div id="Kg" class="col WeightOptions">
<input type="number" class="input Weight form-control" name="WeightKg" id="WeightKg" placeholder="Kilograms" value="<?php echo(isset($_GET['v2'])?ValidatedField("healthscreeningform_476","WeightKg"):$rsEDITFORM->getColumnVal("WeightKg")) ?>">
<div class="input-group-text">kg</div>
</div>
</div>
</div>
<div id="Lbs" class="col WeightOptions">
<input type="number" class="input Weight form-control" name="WeightLbs" id="WeightLbs" placeholder="Pounds" value="<?php echo(isset($_GET['v2'])?ValidatedField("healthscreeningform_476","WeightLbs"):$rsEDITFORM->getColumnVal("WeightLbs")) ?>">
<div class="input-group-text">lbs</div>
</div>
</div>
</div>
<div class="col">
<div class="button dropdownWeight">
<select name="WeightSelector" id="WeightSelector" class="form-control">
<option value="" <?php if (!(strcmp("", (isset($_GET['v2'])?ValidatedField("healthscreeningform_476","WeightSelector"):$rsEDITFORM->getColumnVal("WeightSelector"))))) {echo "selected=\"selected\"";} ?>>Please Select</option>
<option value="Kg" <?php if (!(strcmp("Kg", (isset($_GET['v2'])?ValidatedField("healthscreeningform_476","WeightSelector"):$rsEDITFORM->getColumnVal("WeightSelector"))))) {echo "selected=\"selected\"";} ?>>Kilograms</option>
<option value="Lbs" <?php if (!(strcmp("Lbs", (isset($_GET['v2'])?ValidatedField("healthscreeningform_476","WeightSelector"):$rsEDITFORM->getColumnVal("WeightSelector"))))) {echo "selected=\"selected\"";} ?>>Pounds</option>
</select>
</div>
</div>
</div>
</div>
</div>
<label for="MCbmi" class="col-sm-4 col-form-label">BMI</label>
<input type="number" class="form-control" name="MCbmi" id="MCbmi" placeholder="BMI" value="<?php echo(isset($_GET['v2'])?ValidatedField("healthscreeningform_476","MCbmi"):$rsEDITFORM->getColumnVal("MCbmi")) ?>" required>
</div>
</div>
I had also started working on some JS, but because the customer has two options for both height and weight, I became completely confused by it.
<script>
$(function() {
$('#HeightSelector').change(function(){
$('.HeightOptions').hide();
$('#' + $(this).val()).show();
</script>
<script>
$(function() {
$('#WeightSelector').change(function(){
$('.WeightOptions').hide();
</script>
<script>
$(document).ready(function(){
$(".input").keyup(function(){
var val1 = +$(".HeightFt").val();
var val2 = +$(".HeightIn").val();
var val3 = +$(".Weight").val();
$("#BMI").val(((val1 + "." + val2)*(val1 + "." + val2))/val3);
</script>
I also attach the page in question. The above code starts at line 995.
Could you help me with this Ray? Happy to arrange a Premium Support session with you.
Thank you.
NJ
This should be easy to get working in a premier support ticket. I have time monday next week... just message me in Skype and we can schedule it.
I'll message you on Monday.
I'm about to try to integrate PayPal Express Checkout on this site too and will, no doubt, run into problems with it, in particular I need to store what's sent back from PayPal into database, and update the order status as paid, and I've no idea how to do any of that.
Speak to you next week. Thank you.
Hi Ray,
We got the BMI calculator sorted out in a previous support ticket, but the client is reporting that tthe BMI field is now defaulting to no decimal place - ie it calculates 20.9 but becomes 20 once saved. Only clicking back in the weight field returns it to the correct figure.
Is it possible to resolve this? It's on the following pages on the Sports Medical Certificates website:
health_screening_form.php
smcadmin/view_order.php
FTP access below.
Thank you.
NJ
elewis93815
The update record server behavior has that column defined as an integer:
$UpdateQuery->bindColumn("MCbmi", "i", "".((isset($_POST["MCbmi"]))?$_POST["MCbmi"]:"") ."", "WA_DEFAULT");
If you change it to double it will allow decimals:
$UpdateQuery->bindColumn("MCbmi", "d", "".((isset($_POST["MCbmi"]))?$_POST["MCbmi"]:"") ."", "WA_DEFAULT");
It may be the same on the insert page.... Also make sure the database column is set as a double instead of integer as well with phpMyAdmin.
Nice one, thank you.
Regards
NJ
That was me that answered that one... I was accidentally logged in as another user while I was looking into issues with his account. Sorry to both of you for the potential confusion.
