kcfinder file flagging as false positive?
Thread begun 2/07/2019 5:16 am by Jamie | Last modified 2/07/2019 9:36 am by Ray Borduin | 1828 views | 5 replies |
Jamie
Hi Ray
Hosting provider just flagged this as malware http://prntscr.com/mhw89u - have removed it and re uploaded the local copy and re-run the scan and it is also flagged as malware (attached is the file itself).
I suppose my query is twofold - 1) is there an alternative to use instead of this file itself and 2) my main concern is if all websites using the 'new' kcfinder system on this host get flagged and become unusable?
Jamie
It is a false positive, but I've fixed it in the latest build anyway. You can manually correct the issue on existing sites by replacing the two files I've attached. They are found in the directory: webassist/kcfinder/js
Jamie
thanks Ray. Is that replace those 2 files and remove base.js?
base.js will be automatically recreated, so you don't even have to delete it. It is just a minified combination of all the /js files.
For some reason when you combine the jquery v1.11 and jqueryui files it gives you virus failure (even though they pass when scanned individually, which is why I believe it is a false positive).
I updated the files to jquery v.1.12 and found the combined version no longer has issues.
Jamie
but if its base.js that is getting flagged as the fals positive, shouldnt it be removed?
It will be automatically recreated the next time you open the kcfinder... you can remove it, but it is going to be replaced automatically, so it isn't necessary.
