Login Page not doing anything
Thread begun 2/05/2019 4:04 am by stevenmcgough | Last modified 4/10/2020 10:36 am by Ray Borduin | 6929 views | 14 replies |
stevenmcgough
It has been a while since I have used MySQLi to work with a site. I have a simple database with a table called "User" - which holds simple login info (user/password etc) I have a done a very straighforward form page to test this login procedure - but on viewing the page - it does nothing at all - no errors, just as if there is nothing chacking or happening at all?
I have pasted the page code below to see if anythjing stands out? - the authentication.php file has been created. Thanks in advance for any replies...
Steve
<?php require_once('Connections/Timesheet.php'); ?>
<?php require_once('webassist/mysqli/authentication.php'); ?>
$Authenticate = new WA_MySQLi_Auth($Timesheet);
$Authenticate->Action = "authenticate";
$Authenticate->Trigger = ((((isset($_GET["Submit"]))?$_GET["Submit"]:"") != ""));
$Authenticate->Name = "PPLLogin";
$Authenticate->Table = "`User`";
$Authenticate->addFilter("PPL", "=", "s", "".((isset($_GET["User"]))?$_GET["User"]:"") ."");
$Authenticate->addFilter("password", "=", "s", "".((isset($_GET["password"]))?$_GET["password"]:"") ."");
$Authenticate->storeResult("PPL", "Name");
$Authenticate->RememberMe = (false);
$Authenticate->SaveLogin = (false);
$Authenticate->AutoReturn = false;
$SuccessRedirect = "TimeEntryForm/index.php";
$FailedRedirect = "http://www.google.com";
if (function_exists("rel2abs")) $SuccessRedirect = $SuccessRedirect?rel2abs($SuccessRedirect,dirname(__FILE__)):"";
if (function_exists("rel2abs")) $FailedRedirect = $FailedRedirect?rel2abs($FailedRedirect,dirname(__FILE__)):"";
$Authenticate->SuccessRedirect = $SuccessRedirect;
$Authenticate->FailRedirect = $FailedRedirect;
$Authenticate->execute();
<!doctype html>
<html>
<head>
<meta charset="utf-8">
</head>
<body>
<form action="" method="get" name="form1" id="form1">
<p>
<label for="User">User:</label>
<input type="text" name="User" id="User">
</p>
<p>
<label for="password">Password:</label>
<input type="password" name="password" id="password">
</p>
<p>
<input type="button" name="Submit" id="Submit" value="Button">
</p>
</form>
</body>
</html>
Nothing stands out... The issue could be on the page: TimeEntryForm/index.php
Maybe that page isn't properly identifying if a user is logged in and it returns them to the login page? Maybe the site is having trouble saving session variables in general?
I'd need FTP access and a URL to reproduce to figure out exactly what is going wrong.
Hans
Hi Ray, I have the same issue on the initial login page. However, if I access another restricted page directly, the redirect works as designed and takes me back to the initial login page and the login attempt is then successful. What am I doing wrong? Thank you, Hans
I'm not sure. Can I get a url with steps to reproduce? If I see it then something might come to mind.
Hans
Thanks, Ray. sending credentials privately.
Odd I haven't seen that before.... Can I get FTP access to debug? I think it might be an issue with the autentication.php file, but I'm going to have to go in and do some testing to figure out why it happens.
Hans
private
I see the issue. It is because you are using the "current page submit" trigger and you are on the index page and don't have a page specified in the url. The easiest solution is to just move to the button press trigger.
Hans
Thanks, Ray, I picked "any form post" from the Trigger menu and it seems to be working now. Is this what you meant with the "button press trigger"?
That should work. I was talking about the Button Press: Button Name trigger that should be there for the login button, but either would work in this case.
