Page redirect not working
Thread begun 2/03/2019 6:22 pm by iain331081 | Last modified 2/04/2019 1:20 pm by Ray Borduin | 648 views | 4 replies |
iain331081
Not sure what's up here, but guessing its probably something minor I should have spotted....
Basically a very small form on a page, which is triggering an email, but not redirecting to the specified URL in the WAUE php code in the header. The insert is working correctly, and the email is sending correctly. Its just the redirect, which should be going to the url ../join2/
I have attached the page below - if you could have a quick look and see if you can spot what I've missed that would be great.
Thank you!
Blank lines of code can prevent redirects... You have blank lines in between code chunks on lines: 428, 429, 449, 450, 470, 490
Try removing those and I think the redirect will start working.
iain331081
Thanks Ray - have removed those spaces now, but still not redirecting. I've attached an updated version of the page.
You have a space character after line 365. That might be the issue.
iain331081
Yup! That's it working now. Thanks Ray.
