Is there any compatibility issues with MySqli and Dreamweaver 2019? I am a user of mysqli_107.
Thread begun 2/01/2019 5:36 pm by morrellaberdeen119358 | Last modified 2/04/2019 10:04 am by Ray Borduin | 991 views | 1 replies |
I had problems establishing a mysqli database connection. It kept giving the message "An Unidentified Error Has Occurred". I hand no such problem if I attempted to use the old mysql connection. After several attempts, it worked. Now, I am receiving the same error, when I attempt to build a recordset and hit the test button.
I use Dreamweaver 2019 without issues. That error usually means there is an issue with the testing server URL attribute in your testing server settings.
Are you using a local database or connecting to your remote database. It could be that your local testing server isn't running or the url is wrong.
