Add Row to Recordset results to use in CSV Header?
Thread begun 2/01/2019 12:07 pm by Steve | Last modified 2/01/2019 2:43 pm by Ray Borduin | 1416 views | 4 replies |
Steve
How can I add a row to a recordsets results to use as a CVS header?
I'm successfully writing a CSV file but there is no Header values. It's easy to generate these in PhpMyAdmin as an exported csv file.
The code below takes the results from $Recordset1 and puts them in an array ($DataArray). But it is overwriting the list of column names.
How can I manually push the row of column names into the 1st position of the array to use as CSV Header values?
// output headers so that the file is downloaded rather than displayed
header('Content-Type: text/csv; charset=utf-8');
header('Content-Disposition: attachment; filename=all-entries.csv');
// output the column headings
$DataArray = array('invTitle','invDescr','Address','City','fid','key','FeatRoofType','FeatSidingType','FeatColor','FeatGarage','FeatCarport','FeatStorShed','FeatGutters','FeatShutters','FeatThermoWindw','FeatDeck','FeatPatio','FeatCeilings','FeatIntWalls','FeatHeating','FeatIntCAir','FeatIntWAir','FeatIntFirePl','FeatIntPantry','FeatIntSkyLight','FeatIntCFan','FeatIntCathC','FeatIntSunRoom','FeatIntGTub','FeatIntBasement','FeatIntWalkInCloset','FeatIntLaundry','FeatApplDishw','FeatApplDryer','FeatApplWasher','FeatApplGarbageD','FeatApplOven','FeatApplMicroW','FeatApplRefridge');
$DataArray = $Recordset1->Results; // puts results into array
// create a file pointer (FP) connected to the output stream
$fp = fopen('php://output', 'w');
foreach ($DataArray as $fields) {
    fputcsv($fp, $fields);
fclose($fp);
update this line:
$DataArray = array_merge($DataArray, $Recordset1->Results); // puts results into array
Steve
I tried array_unshift() also...
array_merge did not work :-(
fclose($fp);
Results are a csv file but no first row matching the manually constructed values.
How about you just write that row separately like:
fputcsv($fp, $DataArray);
Steve
Yup, that works perfectly. Gracias Ray!
Code in case anyone else needs this:
// output the column headings as array
fputcsv($fp, $DataArray); // put initial array into csv
$DataArray = $Recordset1->Results; // puts recordset results into existing array
fclose($fp);
