Validation show if
Thread begun 2/01/2019 2:52 am by María Luisa | Last modified 2/05/2019 9:48 am by Ray Borduin | 1596 views | 5 replies |
María Luisa
Validation show if
Hello
I have my upload form working: it renames the files, and uploads them when the file type and weight conditions are met and it does not upload them when it is not. But now I want that, in case the weight of the file exceeds the allowed limits, a message of Validation show if appears.
I have been consulting the forum, the tutorials of WA and I do not know what can fail in my script so that the messages do not appear when these conditions are broken.
My scripts:
//SCRIPTS renombrar, subir e insertar, dejar mensajes
$statusMsg = '';
function replace_specials_characters($s) {
$s = preg_replace("/á|à|â|ã|ª/","a",$s);
$s = preg_replace("/Á|À|Â|Ã/","A",$s);
$s = preg_replace("/é|è|ê/","e",$s);
$s = preg_replace("/É|È|Ê/","E",$s);
$s = preg_replace("/í|ì|î/","i",$s);
$s = preg_replace("/Í|Ì|Î/","I",$s);
$s = preg_replace("/ó|ò|ô|õ|º/","o",$s);
$s = preg_replace("/Ó|Ò|Ô|Õ/","O",$s);
$s = preg_replace("/ú|ù|û|ü/","u",$s);
$s = preg_replace("/Ú|Ù|Û/","U",$s);
$s = str_replace(" ","-",$s);
$s = str_replace("ñ","n",$s);
$s = str_replace("Ñ","N",$s);
$s = preg_replace('/[^a-zA-Z0-9_.-]/', '-', $s);
if (strpos($s,".") !== false) $s = substr($s, 0 , (strrpos($s, ".")));
return $s;
//campo file: V1Pru
//boton: FAIV1
//form: FAIv1Pru
//reemplazar caracteres ilegales y añadir la fecha al nombre
if(isset($_POST["FAIV1"]) && !empty($_FILES["V1Pru"]["name"])){
$dataV = date('Y-m-d');
$nombreVideo = replace_specials_characters($_FILES["V1Pru"]["name"]);
$nombreVideoBBDD = $dataV."_".$nombreVideo;
//campo file: V1Cert
//boton: FAIV1
//form: FAIv1Pru
if(isset($_POST["FAIV1"]) && !empty($_FILES["V1Cert"]["name"])){
$dataC = date('Y-m-d');
$nombreDoc = replace_specials_characters($_FILES["V1Cert"]["name"]);
$nombreDocBBDD = $dataC."_".$nombreDoc;
if (isset($_POST["FAIV1"]) || isset($_POST["FAIV1_x"])) {
$WAFV_Redirect = "";
$_SESSION['WAVT_crearFAI2_506_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateNM(((isset($_FILES["V1Pru"]))?$_FILES["V1Pru"]["size"]:"") . "",0,52428800,0," ,",true,5);
$WAFV_Errors .= WAValidateNM(((isset($_FILES["V1Cert"]))?$_FILES["V1Cert"]["size"]:"") . "",0,12582912,0," ,",true,5);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"crearFAI2_506");
//*****UPLOAD VIDEO*****///
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "__02_video_pru/",
'FileName' => "$nombreVideoBBDD",
'DefaultFileName' => "",
'ResizeType' => "0",
'ResizeWidth' => "0",
'ResizeHeight' => "0",
'ResizeFillColor' => "" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End?>
// WA_UploadResult2 Params Start
$WA_UploadResult2_Params = array();
// WA_UploadResult2_1 Start
$WA_UploadResult2_Params["WA_UploadResult2_1"] = array(
'UploadFolder' => "__03_pru_cert/",
'FileName' => "$nombreDocBBDD",
// WA_UploadResult2_1 End
// WA_UploadResult2 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["FAIV1"]) || isset($_POST["FAIV1_x"])){
WA_DFP_UploadFiles("WA_UploadResult1", "V1Pru", "2", "$nombreVideoBBDD", "false", $WA_UploadResult1_Params);
WA_DFP_SetupUploadStatusStruct("WA_UploadResult2");
WA_DFP_UploadFiles("WA_UploadResult2", "V1Cert", "2", "$nombreDocBBDD", "false", $WA_UploadResult2_Params);
My form:
<form method="post" action="" name="FAIv1Pru" id="FAIv1Pru" enctype="multipart/form-data">
<label for="V1Date" style="color:#4437A3; font-weight:800;">Indicar fecha del vídeo 1</label>
<input type="text" class="form-control" name="V1Date" placeholder="aaaa-mm-dd" required>
<input type="hidden" name="MAX_FILE_SIZE" value="52428800" />
<!--upload video 1-->
<label for="V1Pru" style="color:#4437A3; font-weight:800;">Subir vídeo Ensayo de Prueba</label>
if (ValidatedField('crearFAI2_506','crearFAI2_506')) {
if ((strpos((",".ValidatedField("crearFAI2_506","crearFAI2_506").","), "," . "1" . ",") !== false || "1" == "")) {
if (!(false)) {
<span style="color:#ffffff; background-color:#ff0000; padding:4px; text-align:center;"> El tamaño de su documento debe ser inferior a 50 MB. Comprímalo. </span>
<?php //WAFV_Conditional crear_FAI_2.php crearFAI2_506(1:)
<input type="file" name="V1Pru" id="V1Pru" accept="video/mp4,video/x-m4v,video/*" >
<!--upload cert 1-->
<label for="V1Cert" style="color:#4437A3; font-weight:800;">Subir certificado Ensayo de Prueba</label>
if ((strpos((",".ValidatedField("crearFAI2_506","crearFAI2_506").","), "," . "2" . ",") !== false || "2" == "")) {
if (!(false)) {
<span style="color:#ffffff; background-color:#ff0000; padding:4px; text-align:center;"> El tamaño de su documento debe ser inferior a 12 MB. Comprímalo. </span>
<?php //WAFV_Conditional crear_FAI_2.php crearFAI2_506(2:)
<input type="file" class="form-control-file" id="V1Cert" name="V1Cert" accept=".doc, .DOC, .docx, .DOCX">
<input type="submit" value="Subir vídeo Ensayo de Prueba y su documentación" name="FAIV1" style="width:100%; background-color:#1837A3; color:#ffffff; padding:8px;">
</form>
Does anyone have an idea about what is wrong?
Thank you
It looks like there is an issue with your form validation... you have:
The last argument is the identifier... so you have them both set to: 5
They need to be unique and match the show IF code.... your show if code looks like it uses identifiers "1" and "2", so the code should be:
$WAFV_Errors .= WAValidateNM(((isset($_FILES["V1Pru"]))?$_FILES["V1Pru"]["size"]:"") . "",0,52428800,0," ,",true,1);
$WAFV_Errors .= WAValidateNM(((isset($_FILES["V1Cert"]))?$_FILES["V1Cert"]["size"]:"") . "",0,12582912,0," ,",true,2);
María Luisa
I still have the problem
Hello Ray, thanks for answering.
The truth is that I still have the problem.
I have updated my validation script as well:
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateNM(((isset($_FILES["V1Pru"]))?$_FILES["V1Pru"]["size"]:"") . "",100,52428800,0," ,",true,1);
$WAFV_Errors .= WAValidateNM(((isset($_FILES["V1Cert"]))?$_FILES["V1Cert"]["size"]:"") . "",10,12582912,0," ,",true,2);
The validation show if they are placed in two span tags like this:
And it still happens that if the condition is met (the size of the files is less than required) the files go up and if it is not met they do not go up, although in this case they do not show the error messages to warn the user that they need to compress them, it's what I want...
Could it be because my name change script interferes to remove particular characters from my language and add the date to the name?
Can you or someone give me a clue?
Thank you
Please attach the entire page and I can open it in Dreamweaver and take a look.
María Luisa
Hi Ray
Thank you very much for looking at the file.
A greeting
It appears correct to me. Can you send me FTP access and a URL so I can debug it... maybe session variables aren't working properly on your site?
