Not losing information on page1 when going back from page 2
Thread begun 1/28/2019 11:20 am by john70964 | Last modified 2/05/2019 11:03 am by Ray Borduin | 5195 views | 31 replies |
john70964
I believe there is a way of not loosing the data on a page inserted in input fields when going back from the next page.
eg
Fill in data on page 1
Go to page 2
Go back to page 1
Data in page 1 still shows.
How is this done please?
Many thanks
John
Probably the easiest technique is to use the "Persistent form" server behavior to save the contents of the first page as it is submitted so that you can re-populate the form from the persistent values when someone returns to the page.
john70964
Thanks Ray
I have two pages
Page 1 is where I fill in the data fields
Page 2 is used to send images from
I placed <?php require_once("../webassist/forms/persist.php"); ?> on line 5
of page 2 but the data was not saved on page1.
Am I on the right track?
donegan
What is the form action on page 1?
You should apply the Server Behavior on the action page: Webassist->Persistence->Persist Form
That will add the include and a few lines of code to save the form.
john70964
Thanks donegan
In the webassist folders I do not have a folder named > Persistance
On Page1
Line 174 <form action="<?php echo $editFormAction; ?>" name="form" method="POST">
Line 62 64
$editFormAction = $_SERVER['PHP_SELF'];
if (isset($_SERVER['QUERY_STRING'])) {
$editFormAction .= "?" . htmlentities($_SERVER['QUERY_STRING']);
john70964
Hi Ray
a bit more info below
That means the page submits to itself. Apply the persist form server behavior on page1 and then bind all of the values of the form to get their content from the persistent form binding that will appear in the bindings tab.
john70964
Thanks Ray
I found the persistence form in server behaviours > webassist/persistance
To insert the code
In design view I selected the field
In Bindings I selected Persistent Form then selected the same Field selected in design view
BindTo: shows input value and then select Bind
The page code shows
<input name="Manufacturer" type="text" id="Manufacturer" value="<?php echo(WA_getSavedFormValue("PersistFreeForm","Manufacturer")) ?>" /></td>
But on going back to page one the field entries are not saved.
On using the Next button I am getting 2 errors
Notice: Undefined index: Image1 in C:\xampp\htdocs\boatsforsalenow_mysqli\webassist\file_manipulation\helperphp.php on line 72
Parse error: syntax error, unexpected 'else' (T_ELSE) in C:\xampp\htdocs\boatsforsalenow_mysqli\webassist\email\WA_Email.php on line 176.
Change the persistent form server behavior to use the button press trigger instead of "always".... with always, it resets when you return to the page and makes it blank.
Attach a copy of the WA_Email.php page and I can take a look at it to see why it might have an error.
The error when you hit next sounds like it might be a trigger issue for a file upload on the second page. Make sure that is set to file upload based on the form button so it doesn't try to run right when the page loads as well.
john70964
Thank you Ray
please see PM
