When submitting form I get an HTTP 500 Internal Server Error
Thread began 9/11/2009 1:08 am by peter206417 | Last modified 9/11/2009 12:55 pm by Jason Byrnes | 8518 views | 3 replies |
peter206417
I am using WAUnivEmail280. I have created a very simple form but when submitted I get an HTTP 500 Internal Server Error. The service provider says its a coding problem and they can't help me. I have tried both CDONTS & CDOSYS, both give the same error. To view the page please go to enquiry.asp
The browser displays the following error:
CDO.Message.1 error '80040213'
The transport failed to connect to the server.
/WA_Universal_Email/CDOSYS_VB.asp, line 144
The error means that the SMTP server address that you entered on the Email Object tab is not valid. Double check that you are entering a valid SMTP server address. You may want to check with your host to determine the correct address to use.
peter206417
Many Thanks
Many thanks Jason, the port number was also wrong.
You're welcome.
