Forgot password sends correct email to reset password but shows all the user details with the error "Warning: Cannot modify header information - headers already sent by ..."
Thread begun 1/26/2019 9:38 pm by jim.young353872 | Last modified 2/05/2019 10:51 am by Ray Borduin | 1846 views | 5 replies |
jim.young353872
used security assist to create login, logout, forgot password, etc. pages with Sha1 security. It all works great but when someone uses the "forgot password page" it throws up an error "Warning: Cannot modify header information - headers already sent by (output started at /home/wpscfadmin/public_html/webassist/security_assist/helper_php.php:216) in /home/wpscfadmin/public_html/webassist/security_assist/helper_php.php on line 306 and lists the user info on the page..... The email actually gets sent and the link works it's just disconcerting to a user to see the error and their info show up on the page and they assume the email did not get sent to them.
Please attach a copy of: webassist/security_assist/helper_php.php
I'll see if I can spot the issue on those lines.
TroyD
Ray,
This same thing is happening to me in a staging version of a site I am converting to MySQLi on my local server. It was an older version of forgotpassword.php that I am updating.
It is dumping an array of all of the user's information on the screen. I've attached the helper_php.php file used on this site.
I commented out line 216, but now the header warning moved on to line 217 and 306. I'm not seeing any white spaces, but I'm sure you will find the problem quickly.
Thanks,
TroyD
This appears to be an older version of that file. Please reinstall DataBridge so that it will use the most recent version in future applications. For now, you can also replace this file on the sites you have the issue on with the version I have attached.
TroyD
Thanks Ray, I will do that. Do I need to delete the file in order to get DB to regenerate it?
Thanks,
TroyD
I would to be safe. We are updating our extensions to detect the version number and replace when necessary, but that hasn't been implemented in all interfaces yet. It will definitely re-generate when the file has been deleted.
