Authnet claiming our current eCart will soon fail due to MD5 Hash usage
Thread begun 1/24/2019 11:19 am by Steve | Last modified 1/24/2019 1:12 pm by Ray Borduin | 3030 views | 9 replies |
Steve
Hello,
Has this been addressed in the current version of ecart or is there a document that outlines sorting this issue as reported to us from Authorize.net?
""Authorize.Net is phasing out the MD5 hash, an older method used by shopping carts, payment modules and plugins to verify that transaction responses are genuine and from Authorize.Net. We have identified that you have this feature configured and may be relying on this older method.
Please contact your web developer or solutions provider and confirm if you are using an MD5-based hash. If so, you should begin plans for moving to SHA-512 hash via Signature Key.""
Steve
More Details:
https://support.authorize.net/s/article/MD5-Hash-End-of-Life-Signature-Key-Replacement?utm_campaign=19Q2+MD5+Hash+EOL+Merchant+Reminder&utm_medium=email&utm_source=Eloqua
I've traced the AuthNet_PHP.php pages switch parameter for case "MD5 Hash" as being $retVal = $valArray[37]; which looks to confirm the noted case.
Is there an updated file we can swap out to sort this issue?
Are you using AIM or SIM? I don't think you actually have to do anything if you use AIM. If you are using SIM then I will help you in a screen sharing session. I haven't done the update yet, but I need someone with an active account to work it out. It should be easy enough to make the change.
Steve
Ray,
I'll need to confirm whether it is SIM or AIM. Would you know how to get this confirmation? Do I need get the clients access to Authnet or is this determined in a webassist cart file/setting?
Do you stay on your website for checkout or do you see the checkout form on the authorize.net site? AIM stays on your site and requires SSL. SIM redirects you to authorize.net for checkout.
Steve
We stay on the site, completing the full process there.
That is AIM then, and I don't think you have to do anything from what I've read. We don't use the MD5 Hash, so it won't matter when they change to a different encryption.
Steve
OK, and the reference to :
case "MD5 Hash":
break;
in "AuthNet_PHP.php" is nothing of concern?
Yes... that is actually never used.
Steve
Thank you for the prompt replies on this matter Ray!
