Connection failing
Thread begun 1/23/2019 6:41 am by john70964 | Last modified 1/25/2019 3:07 pm by Ray Borduin | 3554 views | 9 replies |
john70964
Connection failing
Hi Ray
On my local PC I have some pages to select a product to send an enquiry
The sequence is:
Index page allows a product to be selected > go to Details Page with a button to go to
a > Send an Enquiry page to a > Confirm page and then a Thank you page.
On local host this fails when the Thank you page is opened.
On a remote server the same sequence fails at the details page.
I have placed this with ftp details in a PM
Would you please have look to see what may be wrong.
Many thanks
John
The first page just had a blank line of code on line 4. Without warnings turned on in your php.ini file you won't be able to tell why it isn't redirecting, but a page can't redirect after it starts writing content, and even a space or blank line counts as content. Removing the blank line allowed it to continue to the next page.
The thank you page still had old recordset code and wasn't entirely converted to MySQLi. I converted the remaining elements and that page displays properly now as well.
john70964
Many thanks Ray for that help.
I did not know that leaving a blank line could cause such a problem. On the thank_you page can you indicate where the Old recordset elements were, I had a look through that page on my local site but cannot understand what they may be.
All of the pages are working fine now, so thanks again.
There was an old style recordset on the page below the mysqli one, which referred to a mysqli connection, so that mismatch would cause an error. I removed that, but the references to the data on the page all used: $row_recordset["column"] instead of the mysqli version: $recordset->getColumnVal("column");
I went through and updated all of those as well.
john70964
Thanks so much for the help Ray,
I have been updating some pages on that site and it was noticeable that some non updated pages now opened for the first time with apparently updated Msqli Recordsets. I the left them in position assuming they were correct. Perhaps I should have deleted the original Recordset and replaced it completely with a new one?
I used Beyond Compare2 to see the difference.
Btw I could not find the original Recordset anywhere on the page.
Regards
John
The original recordset was just above the <html> tag. It should automatically remove it and update old references when you update a recordset and change it to a mysqli connection. I'm not sure why it didn't work in this case, but it must have been some sort of glitch.
john70964
Inserting a record page
I have moved on to another page but seem to be getting a similar problem that I cannot update the page toMySqli
I am attaching the code of a page created sometime ago which I am trying to update to mysqli.
I have taken out a number of empty rows and I have removed
mysql_free_result($rsCondition);
mysql_free_result($rsCurrency);
mysql_free_result($rsDisplay);
mysql_free_result($rs_Measure_Beam);
which was at the bottom of the file.
Other than that I cannot see why it should not convert the original page works OK but needs updating.
This section of code still has old recordsets:
mysql_select_db
($database_conn1_i, $conn1_i);
$query_rsCondition = "SELECT * FROM boatcondition";
$rsCondition = mysql_query($query_rsCondition, $conn1_i) or die(mysql_error());
$row_rsCondition = mysql_fetch_assoc($rsCondition);
$totalRows_rsCondition = mysql_num_rows($rsCondition);
mysql_select_db($database_conn1_i, $conn1_i);
$query_rsCurrency = "SELECT * FROM categorycurrency";
$rsCurrency = mysql_query($query_rsCurrency, $conn1_i) or die(mysql_error());
$row_rsCurrency = mysql_fetch_assoc($rsCurrency);
$totalRows_rsCurrency = mysql_num_rows($rsCurrency);
$query_rsDisplay = "SELECT * FROM measuredisplay ORDER BY MeasureIn DESC";
$rsDisplay = mysql_query($query_rsDisplay, $conn1_i) or die(mysql_error());
$row_rsDisplay = mysql_fetch_assoc($rsDisplay);
$totalRows_rsDisplay = mysql_num_rows($rsDisplay);
$query_rs_Measure_Beam = "SELECT * FROM measuredisplay_beam ORDER BY MeasureIn DESC";
$rs_Measure_Beam = mysql_query($query_rs_Measure_Beam, $conn1_i) or die(mysql_error());
$row_rs_Measure_Beam = mysql_fetch_assoc($rs_Measure_Beam);
$totalRows_rs_Measure_Beam = mysql_num_rows($rs_Measure_Beam);
but it looks like the connections have been updated to mysqli, so I'm not sure why they weren't updated to mysqli syntax.
Do the recordsets show up in your server behaviors window? Instead of saving the page as .txt, just attach the actual page so I can open it in Dreamweaver in the future.
I think if you open and re-apply these then they should be updated properly. You may want to break them into separate code chunks first like:
mysql_select_db
mysql_select_db
mysql_select_db
mysql_select_db
That could help it update properly.
john70964
Thanks Ray
I think I have attached the page. I hope this is what you need.
Later I have opened the recordset and they updated.
I can now open the page!!
Regards
John
Good... so I guess you are all set with this page anyway. Let me know if you have any more questions.
