Getting javascript error when trying to create authentication pages
Thread begun 1/22/2019 11:18 am by AI Online | Last modified 1/22/2019 2:32 pm by Ray Borduin | 517 views | 3 replies |
AI Online
Error in user.htm. Please give some information concerning this error ASAP
What is the error message? What do you click on when you see the error?
AI Online
Error Message
while executing applyServer Behavior in Security Assist Authenticate User.htm, a Javascript error occurred
Are you using a standard or MySQLi connection when you get this error? Is this on a blank page? Can you try on a blank page and see if you get a similar error?
Does it connect to the database and show your columns correctly?
If it works on other pages and not on the page you are trying to add it to, then I'll probably need a copy of that page to figure out why. Maybe you could give me FTP access so I can try to apply the same server behavior on the same page. If I can reproduce the error then I'll be able to fix it. If I can't, then I'll probably need to do screen sharing with you to debug this further.
