DataBridge_234.zxp won't install with Adobe Extension Manager CC version 7.2.1.6.
Thread begun 1/20/2019 9:16 pm by wcs438894 | Last modified 1/31/2019 8:39 am by Ray Borduin | 2082 views | 3 replies |
wcs438894
Purchased DataBridge 2 Order #: 83M24054R4086563N. Downloaded DataBridge_234.zxp. Opened Adobe Extension Manager CC version 7.2.1.6. Clicked INSTALL. Selected DataBridge_234.zxp. Immediately get error message: "This extension can not be installed, it requires Dreamweaver version 9 or greater. But, I am already using Dreamweaver CC version 19.0, build 11193 on Windows 10 Pro, version 1803, build 17134.523. I'm 10 versions later! Is your extension not compatible with this latest version of Dreamweaver? How do I get it to install? Will it work with Dreamweaver CC version 19.0, build 11193? If the answer to either of those is "no," how do I get a refund? Thanks.
Adobe dropped support for their extension manager a while back. You can install using any of the free third party extension managers that have been created to take its place. The most common are:
http://www.projectseven.com/products/ex-man/info.htm
and
https://www.dmxzone.com/go/22670/dmxzone-extension-manager-for-dreamweaver/
SCar87011738
Hi Ray,
I have a problem updating DB2 on DW CC 2018.
I downloaded the latest version 2.3.4 and tried to install using the DMXZONE extensions manager.
The installation seems to be in place but once I open a page in DW I get this dialog box and it remain there until I force DW to close. Usually it takes some minutes to install. But it gets stuck there.
What Can I do to remove the extension manually and re-install it from scratch?
TIA
tony
Just remove and reinstall from the DMXZone extension manager. You may have to fully close the Extension Manager from the taskbar before it will work.... I've had that problem when trying to re-add an extension I've just uninstalled.
If you still have issues, then send me a US phone number or Skype contact information in the private area of a reply to this thread and I'll do screen sharing to help you through it.
