convert a page from Mysql to Mysqli
Thread begun 1/16/2019 11:44 am by john70964 | Last modified 1/21/2019 10:30 am by Ray Borduin | 3971 views | 6 replies |
john70964
Hi Ray
I am following the instructions on page
http://www.webassist.com/dreamweaver-extensions/data-bridge
Migrate MySQL pages to MySQLi
I have a results page and a details page
On the results page in Dreamweaver the MySql recordset is opened and it quickly converts to the new
to a MySql_i connection. TheTest brings the correct records on the results page.
When I hover over a link I see detail.php?RecNo=12118 which is correct
However when I click on a link on the detail page I see an error message
Access forbidden!
You don't have permission to access the requested directory.
There is either no index document or the directory is read-protected
and the url /page detail.php is missing in the url.
I have placed further details in a PM
Many thanks
John
I'd have to look at the page to see what is wrong. It looks like a syntax error in the link... it might be a redirect on the details page. It is really hard to say.
john70964
By Changing this line 264 from
<td class="WADAResultsTableCell"><a href="boats_detail.php?RecNo=<?php echo $WADAboats->getColumnVal('RecNo'); ?>"><?php echo($WADAboats->getColumnVal('RecNo')); ?></a></td>
<td class="WADAResultsTableCell"><a href="boats_detail.php?RecNo=<?php echo ($WADAboats->getColumnVal('RecNo')); ?>"><?php echo($WADAboats->getColumnVal('RecNo')); ?></a></td>
on local host
the error message became
Warning: mysql_free_result() expects parameter 1 to be resource, object given in C:\xampp\htdocs\boatsforsalenow_mysqli\Man_SeaLine\boats_detail.php on line 235
Delete line 235. It shouldn't be needed anymore.
john70964
Thanks Ray
I deleted the line and found an error in one of the links.
I now get
Details
This record has been removed.
Later I updated the recordset for the detail page. This opened the page for the first record.
I attach a picture of the recordset. Maybe the Add Variable is incorrect?
The Runtime value can't refer to itself.... it has to be a $_GET variable reference. It should be something like:
<?php echo($_GET["RecNo"]); ?>
john70964
Thanks Ray
I think I have this one solved now it was to do with the way I made the link to the next page and the parameters eg the record id.
