Stripe Integration with eCart
Thread begun 1/15/2019 1:22 pm by eric284736 | Last modified 2/06/2019 11:12 am by Ray Borduin | 3682 views | 11 replies |
eric284736
Hi Ray,
We did a Stripe payment processor setup about 2 or 3 years ago on a Premier support session and I needed to update a line of code.
The original line was setup like this:
name: $('#Last_Name').val() + " - reunion-donation"
I need to capture the full name of the customer so would I change the code to this:
name: $('#Last_Name, #First_Name').val() + " - reunion-donation"
Please advise.
thx
Eric
eric284736
Here is the whole section of code
// this identifies your website in the createToken call below
Stripe.setPublishableKey('pk_live_***********************************');
function stripeResponseHandler(status, response) {
if (response.error) {
// re-enable the submit button
$('#Payment_submit').removeAttr("disabled");
// show the errors on the form
$(".payment-errors").html(response.error.message);
} else {
var form$ = $("#Payment_NewFromBlank_Default");
// token contains id, last4, and card type
var token = response['id'];
// insert the token into the form so it gets submitted to the server
form$.append("<input type='hidden' name='stripeToken' value='" + token + "' />");
// and submit
form$.get(0).submit();
$(document).ready(function() {
$("#Payment_NewFromBlank_Default").submit(function(event) {
document.MM_returnValue = false;
// disable the submit button to prevent repeated clicks
$('#Payment_submit').attr("disabled", "disabled");
// createToken returns immediately - the supplied callback submits the form if there are no errors
Stripe.createToken({
number: $('#Card_Number').val(),
cvc: $('#Card_CVV').val(),
exp_month: $('#Card_Exp_Month').val(),
exp_year: $('#Card_Exp_Year').val(),
address_line1: $('#Address_1').val(),
address_city: $('#City').val(),
address_state: $('#State').val(),
address_zip: $('#Country').val(),
address_country: $('#Postal_Code').val(),
}, stripeResponseHandler);
return false; // submit from callback
</script>
name: $('#Last_Name).val() + " " + $(#First_Name').val() + " - reunion-donation"
eric284736
Thanks Ray!!
eric284736
Hi Ray,
I have one more question about this integration and if it needs to be a premiere support ticket let me know.
Stripe has a metadata field which we could use to capture the orderID and it would make matching orders much easier.
How do I capture the orderID from this statement:
if (isset($_SESSION[$ConditionalQuery->SaveAs])) $ConditionalQuery->addFilter("OrderID", "=", "d", $_SESSION[$ConditionalQuery->SaveAs]);
and apply it to the script:
</script>
Would it be this
metadata: $('#OrderID').val(),
or is it different because that is a session variable?
thx
Eric
Can I see a copy of the page? I think it would be something like:
metadata: "<?php echo($_SESSION["eventcart_OrderID"]); ?>",
eric284736
see pm
Please attach the actual page next time so I can open it with Dreamweaver, it will be much easier for me to read.
I think the right line of code would be:
eric284736
I did attach the page in a zip file. Thanks I will give this a try. Thanks Ray!!
eric284736
Hi Ray,
I added the line but when the Submit button is clicked there is no response. Page is attached.
thx
Eric
