Searching thru more than one field
Thread begun 1/11/2019 12:27 pm by lr_leal239405 | Last modified 2/04/2019 1:41 pm by Ray Borduin | 4587 views | 21 replies |
lr_leal239405
I'd like to unite the Search code that asks for two input fields but turn it into one search field that looks thru two columns. I think you told me once but I can't remember. I have the following:
<label for="ss_title" class="sublabel" >Title:</label>
<input id="ss_title" name="ss_title" type="text" value="<?php echo((isset($_GET["ss_title"])?$_GET["ss_title"]:"")); ?>" class="formTextfield_Medium" tabindex="4" title="Please enter a value.">
</div>
<div class="lineGroup">
<label for="ss_keywords" class="sublabel" >Keywords:</label>
<input id="ss_keywords" name="ss_keywords" type="text" value="<?php echo((isset($_GET["ss_keywords"])?$_GET["ss_keywords"]:"")); ?>" class="formTextfield_Medium" tabindex="5" title="Please enter a value.">
</div>
I want to have one search field look thru both columns instead. Thanks!
If you use the Database Search server behavior and choose type "keyword", then you can multi-select the columns to search and use a single field.
lr_leal239405
I got the server behavior -> + -> Webassist -> MySQLi -> MySQLISearch.
Tried a couple of times with below code but keep getting all the records. What am I doing wrong? Thank you.
FIRST TRY:
$searchWADAss_templates_WADbSearch1 = new WA_MySQLi_Search("WADAss_templates","0=0");
if (isset($_GET["Search"]) || isset($_GET["Search_x"])) {
$searchWADAss_templates_WADbSearch1->clearSearch();
$searchWADAss_templates_WADbSearch1->setSearch(array("type"=>"Key", "comparison"=>"=", "join"=>"AND", "and"=>", ", "or"=>" ", "start_encap"=>"\"", "end_encap"=>"\""), array("ss_title", "ss_keywords"), "s", "");
SECOND TRY:
$searchWADAss_templates_WADbSearch1->setSearch(array("type"=>"Key", "comparison"=>"Includes", "join"=>"AND", "and"=>", ", "or"=>" ", "start_encap"=>"\"", "end_encap"=>"\""), array("ss_title"), "s", "");
$searchWADAss_templates_WADbSearch1->setSearch(array("type"=>"Key", "comparison"=>"Includes", "join"=>"AND", "and"=>", ", "or"=>" ", "start_encap"=>"\"", "end_encap"=>"\""), array("ss_keywords"), "s", "");
FORM LOOKS LIKE THIS:
</div>
The first try looks correct. Is your form method="post" or is it method="get"? The trigger might be wrong.
lr_leal239405
This below. It's get. I changed to post but does the same.
<form class="Basic_Default" id="Search_Basic_Default" name="Search_Basic_Default" method="get" action="spec_sheets_results.php">
</div>
attached is the file:
Please attach the search page as well... "get" was correct based on your code. I just wanted to make sure it wasn't set to post.
lr_leal239405
That page has the search and is the search results as well, so that attachment should have everything. Thanks.
(So just to reiterate....the search works fine when I had the fields separate for Title and Keywords. It's only with this new code to look thru both in one that it doesn't work)
lr_leal239405
This post has been deleted.
What are the names of the columns in your database you want to search? Did you hand code this or use the interface?
It looks hand coded because you have form field names where you should have column names and the value area is blank.
The code should look something like:
$searchWADAss_templates_WADbSearch1->setSearch(array("type"=>"Key", "comparison"=>"=", "join"=>"AND", "and"=>", ", "or"=>" ", "start_encap"=>"\"", "end_encap"=>"\""), array("DBColumnName1", "DBColumnName2"), "s", "".((isset($_GET["ss_keywords"]))?$_GET["ss_keywords"]:"") ."");
lr_leal239405
the columns names are ss_title and ss_keywords. I got code from interface then replaced the variable names with what I already had (also originally from interface). This is what was generated that was working originally:
$searchWADAss_templates_WADbSearch1 = new WA_MySQLi_Search("WADAss_templates","");
$searchWADAss_templates_WADbSearch1->setSearch(array("type"=>"Edit", "comparison"=>"Includes", "join"=>"AND"), array("ss_title"), "s", "ss_title");
$searchWADAss_templates_WADbSearch1->setSearch(array("type"=>"Edit", "comparison"=>"Includes", "join"=>"AND"), array("ss_keywords"), "s", "ss_keywords");
Then I just wanted to generate the code needed to get search to search thru both columns instead of using two search input fields separately. It originally generated this code thru that server behavior.
$searchRecordset2_1 = new WA_MySQLi_Search("Recordset2","0=0");
if (true) {
$searchRecordset2_1->clearSearch();
$searchRecordset2_1->setSearch(array("type"=>"Key", "comparison"=>"=", "join"=>"AND", "and"=>", ", "or"=>" ", "start_encap"=>"\"", "end_encap"=>"\""), array("ss_title", "ss_keywords"), "s", "");
This was the original form before I took out Title field. I guess I need to change that?
<div id="Search_Basic_Default_ProgressWrapper">
<fieldset class="Basic_Default" id="Search">
<legend class="groupHeader">Search</legend>
</div>
</div>
<span class="buttonFieldGroup" >
<input type="submit" value="Search" class="formButton unstyled" id="Search" name="Search" />
</span>
</fieldset>
</form></div>
