Another Thing Not Working
Thread begun 1/10/2019 10:42 am by vernon webb | Last modified 1/12/2019 12:16 pm by Ray Borduin | 2416 views | 6 replies |
vernon webb
On the search page in Time Management there is a box called "With Rating" when checked it's supposed to only show values that have an Internal Rating, but it is not working. Looks right to me so I'm confused why it's not working.
The With Rating checkbox has a value="0"... see if it works when you update that to value="1"
vernon webb
No sir
Maybe null values were throwing it off... I've updated the search to account for nulls. What search are you doing? How many results do you get and how many do you expect?
vernon webb
I am searching on the Internal Ratings column. If you do a search from 2018-01-01 to 2018-01-11 and you with the "With Rating" it comes up with everything including those with and without ratings (look in the Internal Ratings column, should have 15 results but has all 64)
I updated the page to filter out blank values, null values, and zero values from that column. I think that is the result you were going for.
vernon webb
